2008 F150 4.6L Timing Cover Replacement
Old May 16, 2024 | 12:45 PM
Rwgreen88's Avatar
Default 2008 F150 4.6L Timing Cover Replacement
2008 F150 4.6l Timing Cover Broken. Are the 4.6l and the 5.4l covers the same ones?
The pully boss broke off and can not be repaired.
Can not find a new one anywhere and dont want to put a used one on due to it possible breaking also due to age.
The part number is 7L3Z6019B from the local Ford dealer And when you punch that number in online it comes up a cover for the 5.4l
Old May 16, 2024 | 01:02 PM
That post breaking off might be because the pulley froze and took the post with it.
A used one in decent condition should do the job as long as the pulley bearings are in good condition.
That is a routine maintenance item and can be prevented by replacing the pulley when the belt is replaced.
Is that how the post was broken ?
Old May 16, 2024 | 01:26 PM
Rwgreen88's Avatar
I took the pulley off thinking it was the bad one and it was good and spun freely, When I put it back on and tightened it down it snapped off in 3 pieces with about half the torque required. The belt tension pulley is the bad one but dont matter after the fact.
Vanrebl
Jan 10, 2021 11:49 AM
DrDialtone
Jun 19, 2012 02:55 PM
mechanix_16
Sep 5, 2011 09:16 PM
dfate23
Sep 16, 2010 06:54 PM
clr0813@yahoo.com
Sep 21, 2005 01:42 PM
