2013 F150 Limited AC/HEAT issue on DRIVERS SIDE
Old Feb 6, 2021 | 01:15 PM
Brian Starnes's Avatar
Default 2013 F150 Limited AC/HEAT issue on DRIVERS SIDE
I recently purchased a 2013 F-150 Limited. I live in the Houston area. Yesterday was the first day it was cold in my new truck. I set the heater on 74 but noticed my feet were cold. After some time, I started feeling my vents. No matter what temp setting or changes I make the drivers side temp is cold. The passenger side will blow warm or hot if I change the temp but the drivers side only blows cold.
Is this an expensive fix? Any advice would be highly appreciated.
Old Feb 6, 2021 | 05:38 PM
scott.butler4's Avatar
The pass side temp works correctly.
The driver side temp does not change.
The mode(location of airflow) works correctly on both driver and passenger sides.
From what I understand all three above statements are true, is that correct?
If it is correct then you will need to replace the driver side blend door actuator.
Old Mar 19, 2021 | 02:30 PM
fdazim's Avatar
Just today my truck began blowing cold through all vents on the drivers side.... however, it blows whatever temp (double zone) you set it to on the traveler side. Has anybody had this occur and is there a fast simple fix?? Kodi nox
Old Mar 23, 2021 | 06:37 AM
If you read the previous post you would see it is recommended to replace the driver blend door actuator.
You can find youtub videos on how to replace it, spend a little more and get a ford part, issues with potentiometers in aftermarket actuators.
Critter7r
Sep 18, 2020 02:24 PM
chp1959
Apr 21, 2009 12:22 PM
Ashley S
Jul 25, 2006 02:04 PM
Ashley S
Apr 20, 2006 12:25 AM
MDBLUEPILL
Nov 24, 2005 04:59 PM
