2013 svt raptor seat does not go up it just clicks
Old Jun 21, 2021 | 08:16 AM
  #11
markignite's Avatar
Hello Scott, I have just tested all functions again before removing the seat. If I move the seat towards the steering wheel, I can not move the backrest at the same time. Not move towards the steering wheel, but only move backwards. The backrest can only be moved towards the steering wheel. I think without it to have measured that the seat module is defective, but I'll try it out right away
  #12
markignite's Avatar
Old Jun 21, 2021 | 11:02 AM
  #13
scott.butler4's Avatar
I do not know how to decipher the information in your latest post.
It should be noted that what I have told you to do so far has been based on what you said was wrong in the first post.
Old Jun 21, 2021 | 11:40 AM
  #14
markignite's Avatar
Hello Scott, yes a bit confusing. Except that the seat does not move up, I have found that it is not possible to tilt the seat back when driving back at the same time. But that works with the passenger seat.
Old Jun 21, 2021 | 11:52 AM
  #15
markignite's Avatar
ok now i have found the following work done: i have built the seat in order to be able to work on it. i have noticed that no 0 volt arrives at the plug for the rear height adjustment when pushing in the up direction. Then i removed the module for the seat and cleaned with electronic spray and all plugs. Then I put the seat and everything back together again. Suddenly the seat could be moved up and down again for about 15 minutes. But now the following problem: I now have the problem that the mirrors move as soon as I move the seat and partly by themselves.Maybe too much spray on the module I thought it was dry.Now after another 20 minutes, the seat only sucks move back and forth and the mirrors do not work. I think I need a new module
Old Jun 21, 2021 | 12:26 PM
  #16
markignite's Avatar
I now need a spare part from the USA very quickly. Is there a recommendation where I can get this module reliably and quickly to Germany? Do you have a shop address? I'm going on vacation on July 21st and the module also has to be programmed at a Ford dealer become
LDB415
Sep 11, 2013 04:43 AM
jenmes70
Jul 27, 2013 03:05 PM
AlwaysAnotherProblem
Feb 17, 2012 08:29 PM
cgc68
Jul 17, 2008 10:05 AM
dqkid
Aug 2, 2005 11:39 PM
