2014 F150 4WD 3.5L EcoBoost hard pedal at idle
Old Feb 24, 2025 | 10:58 AM
bill.keith.824@gmail.com's Avatar
Default 2014 F150 4WD 3.5L EcoBoost hard pedal at idle
I have a 2014 F150 4WD 3.5L EcoBoost. At idle I can pump the brake pedal several times and it will become hard as a rock and I lose breaking ability. This becomes a big problem backing up to something like a trailer where you are constantly hitting the brakes. If I rev the engine a little, maybe another 500-1000 rpm I feel the pedal go down and it brakes just fine. I assumed this was an issue with the booster and so I replaced it, but still have the same issue. I connected a vacuum gauge at the port on the booster hose, I measured almost 30 in-Hg at idle, doesn't seem to change if I rev the engine another 1000 rpm. If I press on the brake though it drops to below 10 in-Hg. At this point I believe it is the vacuum pump, but not sure if it could be something else. Thanks
Old Feb 24, 2025 | 03:17 PM
Most of the time , the vacuum pump has gone into partial retirement.. Considering it is 10 years old, very likely the pump needs to be replaced..
Old Mar 31, 2025 | 10:14 AM
I replaced the Vacuum pump with the OEM version and fixed my issue. Thanks.
Old Mar 31, 2025 | 11:36 AM
Thank you for the update.
Burronator
Nov 9, 2024 06:39 AM
DraGonSouL214879
Aug 18, 2024 08:29 AM
Noahhobbs
Apr 18, 2021 09:54 PM
sand pit boss
Nov 7, 2007 08:56 PM
jonas74
Aug 7, 2005 11:25 PM
