2015 F-150 Issues
Old Feb 14, 2023 | 08:17 PM
OSEric's Avatar
Default 2015 F-150 Issues
Hey guys, so, I have a 2015 F-150 XLT Ecoboost 3.5L. A few months ago I started experiencing issues with it. The truck’s RPMs would slightly raise and it would loose all acceleration. I would also get error messages for Hill Start Assist and Advance Track and wrench icon. When the issue first happened if I turned my truck off and turned it back on the issue would go away, and even disappeared for 5 months. Today however, it is the worse it has been.Looking into it I have found some old forums/threads that indicate a faulty throttle body. However, I wanted to try to reach out to people and see if y’all have any advice/recommendations.
Old Feb 15, 2023 | 03:59 AM
raski's Avatar
I would run a code scan first and then clean up all your B+ and ground connections before blindly replacing parts..
Old Apr 26, 2023 | 02:28 AM
bismic's Avatar
Update?
Old Apr 26, 2023 | 11:22 AM
dmckenzie's Avatar
Check your brake pedal switch
Old Apr 26, 2023 | 01:03 PM
There is a problem with the throttle body and not too many places are trained or equipped to test and verify it's correct operation.
Old Apr 26, 2023 | 03:32 PM
raski's Avatar
After two months, I hope he has his problem solved by diagnosing and not condemning an expensive throttle body by guessing on a whim.
Old Apr 26, 2023 | 07:04 PM
bismic's Avatar
Agreed. I just saw a recent post by the OP of this thread, and noticed that this one had no conclusion to it yet ...............
That is frustrating!
Old Apr 27, 2023 | 07:30 AM
I can't tell you exactly what the problem is within the ETC (Electronic Throttle Control), but there is a problem within it.
rorozco1
Nov 15, 2022 02:36 PM
ITAngel
Oct 5, 2021 08:23 PM
Beets
May 23, 2021 07:50 PM
nmdoc
Jun 10, 2014 06:07 PM
