2016 F150 2.7 Ecoboost Temp gauge
Old May 6, 2021 | 11:52 PM
Zack12's Avatar
Default 2016 F150 2.7 Ecoboost Temp gauge
I'm working on a 2016 2.7 ecoboost, the temp gauge is pegged on high all the time fans are on and has a miss. Haven't had a chance to stick a scanner on it yet just looking to see if anyone has had the same problem. To me seems like the wires from the sender have to be grounding/shorting? Any ideas?
Old May 7, 2021 | 08:15 AM
You might consider unplugging the connection from the coolant temp sensor and see if any change. If no change , then suspect a possible wiring problem.
It is a bit of work to open the dash and unplug the signal wire from the gauge, but that could help eliminate the gauge and sending unit, leaving a definite wiring problem.
Romio Niz Romio
Nov 28, 2018 06:15 AM
jrz_custom
Jul 8, 2014 02:04 AM
ottis60
Dec 29, 2012 01:49 AM
ottis60
Dec 28, 2012 03:26 PM
first on race day
Jun 5, 2009 09:03 PM
