2016 unstable idle help
Old Nov 29, 2022 | 02:38 PM
Gingerbeard's Avatar
Default 2016 unstable idle help
I have a 2016 f150 with 75k or so on it. At idle the truck rpms will run stable under 1k for a minute or two, then for a few seconds it'll climb over 1k, it does this cycle without stopping while at idle. This can't be normal behavior while idling in park is it?
Old Nov 29, 2022 | 03:18 PM
A lazy oxygen sensor can sometimes do this, It doesn't respond as quickly as it should to mixture corrections and the engine can respond accordingly.
Old Dec 18, 2022 | 04:41 PM
Calsun's Avatar
I would also check out the CPS or crank position sensor. Inexpensive part but when it starts to fail the spark timing will vary.
jbreen
Feb 1, 2017 09:21 PM
Doncampbell1017
Aug 8, 2016 03:46 AM
oldschool1
Jun 8, 2016 02:16 AM
93 escort wagon
May 14, 2006 12:01 AM
