2018 F150 Transmission/misfire issue
Old Mar 4, 2019 | 02:25 PM
  #31
BigB's Avatar
Originally Posted by Use Common Sense
I may have missed it somewhere. Just out of curiosity, did the noise start after an oil change? Maybe too light or too heavy weight of an oil installed? I may have missed that somewhere. Just throwing ideas out there and grabbing the straws per say.
I know, I run AMSOIL's P.I. fuel additive (which also lubricates the fuel system and upper cylinder area) in my 2015 3.5 ecoboost and the mechanical fuel pump is barely audible unless I have the hood open. Even then, it's quiet. That's the only noise my engine makes. I also run AMSOIL's 10W-30 Signature oil with dual remote by-pass filtration system, so I have 8 qts oil running thru my system instead of the normal 6 from the added capacity.
The truck is 2018 fx4 5.0 10 speed. I bought new in December.It's not a knock noise,but it sounds like a small backfire after accelerating up to about 30-40 mph and you let off. It began at about 3700 miles on it. I took it in at 4200 miles. Dealership did the tsb 18-2354,which changed the transmission shift points some. I checked my oil afterwards and it was low. I went back and asked that according to their service sheet all fluids were checked..??? So it was still making the sound and they kept it for a week. So the oil and filter was changed lDoing an consumption check now. I was told that the sound is a characteristic of those like vehicles. This is coming from Ford and the service manager. No the truck runs great and is not knocking. But the noise is what I am not sure of. I'm going to wait a while and will take it to another dealership to see what they think..I think it's a fuel issue,as in a injector staying open too long. It only does after deceleration or gear shift. There is no jerking. Sounds like a hand clap or a pop in the catylitics..
Old Mar 8, 2019 | 10:59 PM
  #32
knoppers's Avatar
I see you have a FX4, is the truck on sport mode, descent control, trailer tow mode? if so, it could be just engine breaking.
Old Mar 9, 2019 | 04:59 AM
  #33
BigB's Avatar
Default Oil consumption 5.0
. I run in normal mode. The sound is mostly heard at lower gears at higher rpms. After gaining speed and then letting off. There is a procedure that Ford has to go through,but it involves taking the intake off and checking some sort of gate lever. Also Ford has just put out a new TSB for oil consumption on March 1 for the 2018 5.0 liters. It starts with a new PVC valve. Then monitoring the oil levels. The end result could be a long block change out..
Old Mar 10, 2019 | 11:35 PM
  #34
Use Common Sense's Avatar
"It starts with a new PVC valve"...?
Sounds like Ford knows there is a compression/blow-by issue. Which brings me back to their use of the thin coating of spray-on bore liner (Plasma Transferred Wire Arc) and it's actual durability.
Old Mar 11, 2019 | 12:16 AM
  #35
BigB's Avatar
I mentioned something about the bores to the dealers shop foreman. He said that there are liners, but the rings aren't seating well. Thus that could explain the oil consumption. I am down some in a 1000 miles. Getting the PVC renewed today..
Old Apr 9, 2019 | 09:06 PM
  #36
dominatorwvu's Avatar
Update on my truck. I took it back to the dealership. They have had it for 5 days and finally got a phone call from the HEAD service department manager. They are replacing my VCT solenoid. He said that will solve my lack of power, rattling noise, and hesitation/stuttering. Maybe this is confusing something with the tranmisssion the entire time.?!?!?!?
Thoughts or comment?
Old Apr 11, 2019 | 06:01 AM
  #37
BigB's Avatar
Default New long block
The new long block runs and sounds good so far. But there's still the same pop noise as before. Dealership is telling me that it's a normal characteristic of the engine. I'm having a hard time believing that since there are many more trucks that are not having this issue.
Old Jan 16, 2021 | 11:15 PM
  #38
Scott Hightower's Avatar
I own a 2018 xlt 3.5 ecoboost. Recently 8th, 9th and 10th gear are have become very frustrating. I find myself using manual shifting. If in the higher gears, slight throttle increase makes the truck shutter. I can watch the the rpm fluctuate about 200-300 rpms. If I mash the pedal, it will downshift and everything is fine.
Dewy
Mar 19, 2017 12:42 PM
Big Lew
Nov 14, 2014 12:33 PM
Tools94
Aug 24, 2013 03:12 PM
Adrian19
Feb 13, 2012 03:20 AM
summerson1
Jul 25, 2010 06:48 AM
