4r70W No 2nd gear in Drive
Old Oct 24, 2018 | 11:59 AM
RollTide's Avatar
Default 4r70W No 2nd gear in Drive
I have a 2003 F150 5.4 with the 4r70w transmission. I had to rebuild the tranny last summer (clutches were shot). I thought it might be more job than I wanted to tackle, but I did ok. Only issue now is that it won't engage 2nd gear when it's in drive. It just revs up in 1st to about 3500 rpm, then skips right to 3rd. Same way on the downshift. It downshifts fine from 4-3, but when I really get on it, it jumps right down to 1. If I manually shift it to 2nd, it engages. I've done the electrical testing and verified that the pcm is commanding 2nd, but the transmission stays in 1st. I read somewhere that the valve body might be the culprit. Can anyone verify? I'll replace the valve body if I have to, I just want some more input before I spend that money.
Old Oct 28, 2018 | 03:35 AM
It is unusual for all the clutches to be shot at one time,so what caused that? Did you clean the valves in the valve body?
Here again , if there was a lot of crap floating around in the trans, there is a good chance the 1-2 shift section is restricted .
Old Oct 28, 2018 | 11:45 AM
Check ***** all accounted for, and correct placements. Valve body gasket part numbers matched?, if aftermarket ‘ overlay’ proved as correct?
tsamrein
Oct 4, 2019 02:17 PM
petehack
Jan 8, 2015 12:16 PM
shotgun5
Dec 28, 2011 09:27 PM
gstadter
Apr 10, 2011 02:52 PM
dilligaf58
Sep 12, 2006 06:55 PM
