4r70W loses 3rd and 4th after driving short distances
Old Oct 3, 2019 | 10:59 AM
tsamrein's Avatar
Question 4r70W loses 3rd and 4th after driving short distances
Hi all,
I have a 2004 Ford Expedition with the 4r70W and it has a rebuilt transmission and motor in it. I have driven it about 15,000 miles since the rebuilds. It has recently began to have issues with 3rd and 4th gear. I will drive around town and after stopping and starting a few times it will try to shift to 3rd from 2nd and it will free wheel and not shift. I have figured out that either I have to be in 2nd manual or turn hit the O/D off button then it will drive in second and shift from 1st and 2nd to make it home.
Anyway I am looking for advice on what to do to fix this. I have already replaced the shift solenoids and the plastic "wiring harness" that is under the valvebody.
Thanks for any help you may be able to give.
Edit: This happens sometimes after the vehicle has been driven for a while. If I set out on a longer drive it will drive fine as long as it does not shift down to 3rd from 4th or 4th to 2nd pulling a hill.
Old Oct 3, 2019 | 04:22 PM
It sounds like there is a problem within the valve body of the trans.
Did you consider having the vehicle checked for any trans codes?
Old Oct 4, 2019 | 02:17 PM
tsamrein's Avatar
I have read all the codes and I keep getting a Shift Solenoid B code. That is the only code at the moment. Any ideas on what to do to test the Valvebody? I have change the fluid 3 times while changing parts. The EPC is the only electrical item inside the trans that hasn't been replaced.
Rusty Ride
May 6, 2019 09:53 AM
Shade tree 1
May 7, 2015 11:42 PM
shotgun5
Dec 28, 2011 09:27 PM
cobalt076
Jun 6, 2011 09:19 PM
surferbum
Apr 27, 2008 07:23 PM
