83 F150 Electrical problems
Old Sep 14, 2006 | 12:53 AM
samspang's Avatar
Default 83 F150 Electrical problems
I have an 83 f150 with a 5.8L 351. My truck stutters and stops at times when holding down the power window button or when using headlights at night. The alternator and battery are newer. I get a 14.5A reading before starting and it jumps up to around 19.5A when started. The amps will sometimes jump down to 1.0 when holding down power window button. I'm not sure what to do?
Old Sep 14, 2006 | 07:57 AM
94 4x4 ranger's Avatar
Default RE: 83 F150 Electrical problems
[sm=welcomesign.gif]Sounds like the alternator is no good.[hr]When the alternator was replaced what amperage alternator was used?[hr]With power windows,Power lock's,A/C,Ect there should be a higher amp one in there.[hr]Also check and clean all connections at battery,starter,starter relay, alternator,and ground to engine.
willijimon
Oct 21, 2018 08:07 PM
probethrasher
Jun 8, 2010 07:03 PM
mrd
Oct 7, 2005 07:44 PM
mrd
Oct 7, 2005 11:43 AM
Uscgjoe2004
Jul 9, 2005 12:05 PM
