91 f150 running problem!! HELPPPP!!!
Old Feb 6, 2008 | 07:11 AM
bikesbuilder's Avatar
Default 91 f150 running problem!! HELPPPP!!!
Hello everyone! I have a problem with my ford and maybe someone could help me please!!!!
I have a full size extended cab 1991 ford f-150. It starts no problem, idles a little irratic! If you hit the gas slowly, it picks up rpm no problem, but if you hitr the gas hard, the motor boggs down!!!
I have had 4 mechanics look at it: this is what has been done so far!!!
Both Tanks have new feul pumps
New feul filter
New dual tank switch
New fuel relays
The pressure at the rail is 35 psi at idle and 45 when running!!!
New map sensor
New egr sensor
vacume test says the egr is good!
new tps sensor
new ect sensor
new 02 sensors
Does anyone have any Ideas for the problem !!!!!
I like the truck and want it fixed!!!!!
i am a bike builder in Peurto Rico for the last 9 years and originally from Canada!
Thanks!!
Old Feb 6, 2008 | 03:26 PM
oldtimer35's Avatar
Default RE: 91 f150 running problem!! HELPPPP!!!
Have you cleaned the IAC motor? Sounds like it sticks and goes lean, momentarily. A little choke cleaner will tell you if that is the problem. Just spray it into the opening of the IAC with the engine at idle. Then pick up the rpm and continue spraying as you clean.
Old Feb 8, 2008 | 06:10 AM
Thanks for the advice, but I found the problem!!! It was in the computer, one spot had lost contact!!!, added solder to it my self and fixed everythin!!!!!
beam43
Oct 1, 2013 03:06 PM
FL3471
Mar 9, 2013 02:45 AM
96F350Panel
Nov 27, 2007 02:59 PM
Mardav111
Feb 2, 2007 04:37 AM
rrmojica
Dec 17, 2005 02:24 AM
