94 f-150 ac issue
Old Jun 14, 2020 | 05:50 PM
  #11
Corbin's Avatar
To help get the refrigerant gas into the system a little quicker when charging, you might while holding the can UPRIGHT, place it in a pan of warm water to help raise the temp in the container. Just keep an eye on the low side gauge and don't let the gas pressure go much over approx. 50 lbs otherwise remove the can from the warm water and repeat until the container is empty and you will know that when you place the container in the warm water there is no longer an increase in the low side pressure. You only need to place the bottom of the container in the water. You do have your eye protection on right?
Don't know if any damage was done by possible moves earlier, but if it was , well, go from there.
just charged it listening to everything above. The gauges were reading right and then closed it off. After that the high side wouldn’t stop climbing. I’m going to attach a video of what happened after I started it up. Keep an eye on the high side. Ambient temp is 90 degrees and when I stopped filling it the gauges read 35 on the low side and 260 on the high. Not sure why the low is 10 psi under the recommended. After starting the high side won’t stop climbing. Keep in mind before this pic was taken it was at 35 psi on low and 260 on high.
Old Jun 14, 2020 | 05:54 PM
  #12
Corbin's Avatar
This may have been confusing. But I charged it to 35psi low and 260psi high. Shut the truck off and then started it and the gauges were reading that.
Blziegler
Nov 12, 2018 12:25 PM
rwall10597
May 30, 2018 10:41 AM
barngoddess
Aug 27, 2013 01:43 AM
ushisteacher
Oct 20, 2010 12:22 PM
Blkngold
Aug 5, 2007 07:57 PM
