94 f-150 hard starting high idle
Old Jun 17, 2012 | 01:23 PM
945.0f150's Avatar
Default 94 f-150 hard starting high idle
I have a 94 f150 5.0 and im having a hard time getting it to start. i have to push the pedal all the way down to get it to start. After it starts it idles high around 1600. I just replaced tps and iac on it. Im not sure on where to go from here.
Old Jun 17, 2012 | 02:39 PM
When you have the throttle pedal all the way to the floor you place it in clear flood mode.
But, I would suspect that you have a good sized vacuum leak. It can be the throttle body, a vacuum hose off somewhere or even a hose in the wrong place.
Try clamping off each vacuum hose one at a time and see if you get any results.
Old Jun 18, 2012 | 07:50 AM
945.0f150's Avatar
ok i will give it a try thank you. I did notice alot of the hoses are very dry rotted around the throttle body. this is a totally new monster to me ive dealt with gm small blocks my entire life fords are totally different.
lt3355
Jan 4, 2015 09:33 AM
surferjoegomango57
Dec 11, 2013 02:32 PM
Parkse261
Jan 4, 2008 02:23 PM
jkmf250
Mar 29, 2007 05:16 PM
mike0179
Feb 20, 2007 02:56 AM
