94 f150 4.0 keeps beeping
Old Feb 10, 2021 | 10:21 AM
300straight6's Avatar
Thumbs down 94 f150 4.0 keeps beeping
I've gat a 1994 F150 Supercab XL 4.9 When you turn the truck to the off position at the ignition switch, Beeping starts. The only way I've found to stop it is turn the switch to the run position or the battery dies from it beeping. The door, headlight, key in the ignition and seatbelt warning is a buzzing. sound. I checked the door switches as well as seatbelt headlight door switches checked out. Since the problem is the key in the off or removed state. I pulled the ignition switch and removed the key warning connection. Cut the wire and folded it as well as put it in heat shrink tubing. Any one with the same problem or with the fix please let me know. The only other issue I found was when running a OBD test in the KOEO mode. I got a 212 code.
Old Mar 20, 2021 | 09:25 AM
fdazim's Avatar
1994 F150XL, 4.9L, E40D So... I figure I may have caused an issue under the scramble of my truck. My truck has vinyl inside, and vinyl tangle floor. Each time I've washed the truck, I've showered out the floor in the inside. Never had an issue doing this... up to this point. I know, I know... I'm a numbskull. Since I splashed it out, I currently have a signaling sound that is coming from under the drivers side of the scramble. The truck will in any case begin and drive fine, yet at whatever point I shut the truck off, the signaling starts. I think I've discovered the wellspring of the sound, yet I can't be certain. It is by all accounts coming from a black box with blue interfacing plugs. The blare seems like a lethargic morning timer... beep..(1 second of silence)..beep..(1 second of silence)..beep.. etc in this design. It blares around multiple times, at that point stops for around 5 seconds, at that point signals again in a similar example. It does this around multiple times before it quiets for quite a while. I presume the blare is returning intermittently as the truck sits on the grounds that I've heard it signaling in the evening, in addition to my battery is done holding a charge, so I believe it's running it down. Any thoughts regarding what this is?
192.168.100.1 192.168.1.1
Old Mar 20, 2021 | 12:08 PM
RCM, Restraints Control Module its signaling a fail code.
If was exposed to moisture/water, it could have internally shorted/faulted. If you can count the exact tones it would help ID the specific fail code.
The 5 second pause is a separator , so the count tones don't run together...
boomboom1966
Feb 3, 2013 05:37 PM
taztank
Dec 22, 2011 12:31 PM
RangerFan1994
Jun 8, 2010 10:56 AM
John Begin
May 8, 2010 08:30 PM
ExplorerOnKrome3152
Mar 11, 2007 12:53 AM
