94 F150 Fuel Tank/Pump Issues
Old Sep 29, 2024 | 07:29 PM
KwilliatxF150's Avatar
Default 94 F150 Fuel Tank/Pump Issues
Rather than revive my two year old thread regarding my 94 F150, 5.0, 4x4, dual tanks, I thought it best to start a new one since the problem is different than what I originally posted about. The current problem is that after replacing both fuel pumps and the selector switch, and everything working as it should, the truck started pulling fuel from the rear tank to the front tank, even if both were full. My questions now are: 1. Can I convert the truck to a single tank using either the front or rear tank? 2. If I can, would it be easier to use the front or the rear? 3. What parts would I probably have to buy in order to make this conversion?
Old Sep 29, 2024 | 08:51 PM
There is a problem with the shuttle valve in the front tank unit.
If you only replaced the pump, you need to replace the entire unit (module) sending unit and all.
You have a convenient set up and it would be a shame to attempt to butcher it up.
It may also be lower cost in the long run.
Old Sep 30, 2024 | 11:46 AM
Thank you, Hanky. I'll check that out since right now the truck won't start off of either tank.
Old Sep 30, 2024 | 02:17 PM
I realize you did not ask, but if it cranks OK, pull a spark plug and that could tell us if you have a fuel supply or ign system problem.
If you have the tools and background to replace fuel pumps maybe we can offer something to make the problem easier to correct.
Old Oct 2, 2024 | 06:15 PM
Checked today. No spark this time.
Old Oct 2, 2024 | 06:22 PM
I would suggest start with checking all the fuses. It is no fun after doing a lot of unnecessary work only to find a fuse was open..
Old Oct 2, 2024 | 07:25 PM
We'll give that a try, probably tomorrow. It's getting dark now. Thank you.
Old Oct 3, 2024 | 04:33 PM
Okay. Have power from the ICM to the coil, one fuse replaced; but, no power to the distributor. I assume that's why there's no spark at the plugs. Could it still be a bad coil? Update: The coil, distributor cap and rotor have been replaced, and still no start. A test on the ICM found that with a test light, the light is off when the key is in the "ON" position, and 12.5 volts when the key is in the "OFF" position. So, my question now is, could the ICM be bad? There's still nothing to the distributor. My other question is, could this be the ignition switch.
TIA
Last edited by KwilliatxF150; Oct 3, 2024 at 09:25 PM. Reason: Adding additional info about no start condition
Danny2020
Dec 25, 2020 11:59 PM
94f150
Oct 17, 2020 07:06 AM
kruzer65
Dec 4, 2017 10:17 AM
yankees27
Aug 9, 2012 12:36 PM
mdof4
Jun 23, 2010 07:07 PM
