95 f150 5.0 302L
Old Feb 4, 2017 | 07:23 PM
Cody Turpen's Avatar
Default 95 f150 5.0 302L
I have replaced the icm, coil pack, cap and rotar, still started an ran tell the day after I replaced icm. Won't start at all, unless I pull #1 plug an leave it out then fires right of an runs good besides the miss. But once plug is put back in, its back to not firen. What would cause this? has me stumped. I'm thinken bad plug but it doesn't even hit off if the wire is disconnected.
Old Feb 5, 2017 | 03:58 PM
Cody,
How many miles are on your vehicle?
I would suspect there may be a problem with the wires coming off the dist cap. Did you replace the wires onto the replacement cap one at a time or ,,,,,,,,,,all at once?
Did you put the new cap on to make sure you placed the wires in the exact same location as on the old cap?
rusty ol ranger
Sep 9, 2005 06:36 PM
