95 f150 heater won't blow hot
Old Nov 29, 2018 | 09:12 AM
JoeGorman's Avatar
Default 95 f150 heater won't blow hot
My 95 f 150 4th won't blow hot air out of the vents. Heater core gets hot and actuator door is hood blower motor is good. Please help
Old Nov 29, 2018 | 11:53 AM
How about a little help from you?
What does 4th mean?
Please explain, heater core gets hot, how was this determined?
When you say vents, does this mean only the vent setting or other functions also like defroster ,floor etc ?
Not knowing where you reside, could the intake areas outside just under the windshield be clogged with ice or snow?
Old Nov 29, 2018 | 12:58 PM
JoeGorman's Avatar
What does 4th mean?
95 ford f 150 replaced actuator door . flushed system,replaced thermostat. Both heater core hoses get really hot. Box around hearer core gets so hot you cant touch it but vents will only blow warm air on any setting.
Old Nov 30, 2018 | 03:27 AM
There is a "Blend door" that most likely is stuck in the position where it is not directing all incoming air to go over the heater core.
paulv718
Jan 18, 2017 09:23 PM
jchittick34
Nov 12, 2011 06:09 AM
1999EBEXP
Oct 24, 2011 10:58 AM
Junglemon
Feb 24, 2011 03:31 PM
95vic
Jan 17, 2008 10:11 AM
