95 f150-Stuck in 2nd Gear?
Old May 17, 2013 | 09:26 PM
NakkedCowgirl's Avatar
Default 95 f150-Stuck in 2nd Gear?
I've got a '95 F150 5 speed. Today when I was on the road and went to put it in 2nd, the shifter hit the seat. Obviously not the proper 2nd gear position.
Also, the past few days, when I go to put it in reverse it won't reverse until I put it back in first and fiddle around with it, then slide it into reverse again.
Can anybody offer me any insight? Thanks in advance, anything helps.
Old May 19, 2013 | 02:33 PM
59 Edsel's Avatar
Just a guess but sounds like the bushing for shift linkage is worn out. pull the boot up and see what it looks like ?
Guess you could always stay in 2nd gear ? Always go foward ? ?
Old May 19, 2013 | 02:48 PM
If you remove the floor pan cover over the trans , you should be able to lift the boot and check the ball on the shift lever. They have a habit of wearing out and getting real sloppy and difficult to shift into the correct gears.If that is all it is , it can be easily repaired without removing the trans.
shad9876
Mar 6, 2017 08:47 AM
Yapalot
Apr 26, 2011 05:29 PM
signalmaster509
Jun 12, 2009 09:16 AM
dilligaf58
Sep 12, 2006 07:57 PM
dilligaf58
Sep 12, 2006 06:55 PM
