95 ford f150
Old Nov 10, 2019 | 08:39 AM
D1995's Avatar
Default 95 ford f150
Ok the truck wouldnt start i fixed that thanks to u guys now when i go to give it gas it trys to cut out and spits and sputters also back fires out the intake now if i peddle it it will rev up it has a new throttle position sensor new fuel regulator new dist cap and rotor button new igntion coil. it idles fine so someone plz help
Old Nov 10, 2019 | 10:34 AM
Not knowing exactly how you replaced the dist cap, , also did you have this problem before replacing all those parts?
Could you fill us in on those two questions ? If any wires are in the wrong place , well,,,,,,,,,,,,,,,,let see first , OK?
Old Nov 10, 2019 | 10:57 AM
D1995's Avatar
Ok no before i replaced the parts the truck wouldnt start cuz the regulator was bad and i did the wires one at a time when i was putting them on the dist
Old Nov 10, 2019 | 12:00 PM
OK, so let's check the timing
In the direction of normal engine rotation, You can use the alt pulley to do this,bring the timing mark on the crankshaft pulley, TDC and line it up with the pointer on the timing chain cover Now remove the dist cap and see where the rotor is pointing. It should be pointing exactly at the #1 terminal on the dist cap. If it is way off rotate the engine one more turn and that should be at the #1 tower on the cap. The dist shaft rotates counterclockwise . If it is past the tower on the cap , it is too far advanced. rotate the dist so the rotor points directly to that #1 wire position on the cap. Install the cap and see if there is any difference. This should be done with a timing light, but don't know if you have access to one.. If everything else is OK the engine should run OK. Fine tuning should be done with a timing light..
Also, check that plug wires for cyls 5 & 6 do not run close to (parallel) to one another. Firing order should be, 1-3-7-2-6-5-4-8. (5.8 L engine) .
Old Nov 11, 2019 | 05:16 AM
D1995's Avatar
We checked timing everything seems good its kinda lime its getteing to much air when i go to get on the throttle im stumped other than o2 sensor maf sensor something like that causeing it
Old Nov 11, 2019 | 05:48 AM
raski's Avatar
Check fuel pressure, should be 30-45 psi and hold after shutdown. Atleast make sure the fuel filter isn't obstructed.
Old Nov 11, 2019 | 06:55 AM
D1995's Avatar
Fuel pressure is good it has new fuel pressure regulator idle position sensor and i just went out and started it it will idle great then out of nowhere it shuts off but starts right back up and does fine for a few mins again
Old Nov 17, 2019 | 06:57 AM
raski's Avatar
Did you actually measure it or just stick the shrader valve?
I would hang a gauge, do drive and see what is is when the engine actually dies.
Old Nov 17, 2019 | 11:39 AM
If everything checks out as far as fuel pressure is concerned, you may need to go to the ign system. If there is weak spark, the engine cannot perform under load.
Were you able to check all the connections to the coil and ign module? Don't overlook the plug that goes to the ECM under the pass side heater hoses. (10 mmbolt head)
I have seen where the coil would break down internally with temp and provide no or very poor spark.
Something you might try, If you know the engine will quit running after a certain period of idling, set one plug wire so the spark can still get to the plug, but so you can see it also. If it is not a lengthy period of time watch to see if the spark stops just before the engine quits. If it does, go after the ign syst. This is easier with a timing light , but don't know if you have one to use..
Can you provide the engine code from the sticker on the door pillar ?
James Baker
Mar 16, 2017 09:06 PM
Old4xford
Jan 26, 2012 04:41 PM
jack of trades
Dec 13, 2011 07:58 PM
dlingner
Sep 26, 2009 11:58 PM
darylsr
Jul 16, 2008 01:14 AM
