96 f150 transmission trouble
Old Jan 25, 2016 | 02:02 PM
Treeder76's Avatar
Default 96 f150 transmission trouble
I go 1996 f150 extended cab with automatic transmission. Blew transmission lines loss alot of fluid.fixed lines then drove 4 miles and parked. Now it won't move at all any ideas as to why would be greatly appreciated. Trans was rebuilt 5 yrs ago so that should be good still. Odd part is after fixing it drove and shifted fine. Please help.
Old Jan 25, 2016 | 08:03 PM
Welcome to the site..
Fixed line/s, and replaced lost fluid (?). Checked idling in park after warmed up...
Old Jan 25, 2016 | 08:41 PM
Treeder76's Avatar
Sure did in a level parking. Showed a bit over but not a whole lot. If that could be issue I can loosen line and drain some.
Old Jan 26, 2016 | 02:53 PM
LakelandFordParts's Avatar
Former Sponsor
If you drove 4 miles with little/no transmission fluid you may have caused some major damage.
Old Jan 26, 2016 | 07:29 PM
Treeder76's Avatar
Would it still let it work for the test trip and then go out. Just doesn't make sense. And honestly it was more 2/10 of mile after the line went and wasn't going fast.
Old Jan 27, 2016 | 09:00 AM
Former Sponsor
That is odd, you may want to drop the pan and do a flush just to see if there is any metal in it.
Old Jan 27, 2016 | 10:47 AM
Shay_Fox's Avatar
Agreed with you lakelandFordParts..!!
Old Jan 27, 2016 | 07:55 PM
Treeder76's Avatar
So I had a local mechanic look at n said it bad but didnt drop pan is that possible to tell.
Old Jan 27, 2016 | 08:38 PM
Did he install a pressure test gauge in the tap plug and check for spec line pressures?
Pan wouldn't need to be dropped to test for line pressure and if not moving,, would be a first step check point, maybe more so if the trans/pump was lube starved. If it's full and not making pressure, could be pump related. Taking a look into the pan can sometime give an indication of a hard parts failure..
Bronco76Ranger00
Nov 8, 2009 08:24 PM
randyhawk
Apr 17, 2009 03:43 AM
Cheryl
Jul 10, 2008 07:58 PM
roger33
Sep 29, 2006 05:55 PM
mrwhipper
Dec 23, 2005 06:10 PM
