97 f-150
Old Apr 8, 2019 | 06:20 AM
Kammerron's Avatar
Default 97 f-150
Looking for some direction on how to repair my truck.
Know issues:
Serptine belt slipping
AC pully starting and stopping even when AC is in off position.
rough idle.
Old Apr 8, 2019 | 07:25 PM
A compressor clutch bearing that is starting to run dry can produce those symptoms. Only the bearing itself would need to be replaced, . If the belt has been slipping , replacing the belt also would be a good move.
Old Apr 10, 2019 | 07:01 PM
raski's Avatar
Know issues:
rough idle.
1. worn belt, tensioner weak or seized or accessory is loading down belt.
2.a/c- I would try disconnecting the field coil connection for the A/C clutch to see if it is a mechanical or electrical issue.
3.If your truck has OBD2, connect a scan tool and look at fuel trims and possible codes.Many things can cause rough idle. This is where you shoould do some diagnostic work and do not guess with new parts. Vacuum leaks, ignition fuel system problem.
rstyll
Oct 22, 2019 02:48 AM
bradleyheathhays
Feb 11, 2019 08:54 PM
jstad
Oct 16, 2016 10:29 PM
always got trouble
Aug 13, 2013 02:29 AM
Firehousebikes
Apr 14, 2011 04:07 PM
