'97 f150 4x4
Old Jul 10, 2022 | 03:28 PM
jjinx's Avatar
Default '97 f150 4x4
have a question on what i should do next.
I have a 97 f150 4x4 that had a misfire cylinder #2 did everything from replace plugs and wires to injectors. now the truck starts up but won't continue to idle unless given a little throttle, then itll idle but really rough. also blowing white smoke like a chimney. any recommendations to fix this
thank you
Old Jul 10, 2022 | 05:01 PM
jjinx's Avatar
just went and looked at the fuel filter and noticed that the exhaust pipe close to the filter is leaking fuel... would that be caused by the injector being open and leaking fuel??
Old Jul 10, 2022 | 08:41 PM
If you changed the fuel filter, there are little "O" rings that are located inside the female fuel line connectors that go on to the filter.
One of them maybe came out and wasn't noticed . They are special O rings that are resistant to gasoline , regular O rings will not work there.
They are only about 3/8 in in diameter, with about a 1/4 in center hole and are usually tan in color. Last time I needed one , only dealer had them.
If you check maybe the connectors were not on all the way. Keep in mind that line is under at least 40 lbs pressure or more.
item9
Mar 1, 2012 08:39 AM
TGSTP
Feb 13, 2011 01:39 PM
crash!!
Jun 23, 2008 09:37 PM
machine72
May 6, 2008 04:21 PM
Hendu2875
Apr 14, 2006 12:58 PM
