Advice?
Old Sep 27, 2011 | 10:27 AM
Trin Cruz's Avatar
Default Advice?
I got a 94 f-150 that is on 79 dana 60 3/4 ton axles. It has a very bad suspension lift that is just bolted on and can not even manuever well, so i went to the junkyard yesterday and found a 91 f250 which is 4x4. I was thinkin on replacing the dana 60 axles with the f250 axles cause there more modern and stuff. Would it be that hard to put them under my f150? And after i would put them f250 axles under it i was thinkin on puttin a 6 inch suspension lift on it...probably skyjacker. It also has a 3inch body lift which i would like to keep and then add the 6 inch to it for a total of 9 inches. What size tires would i be able to put under it when its done? and what do you guys think about my idea???????
Any advice wouod be great! thanks
Old Sep 28, 2011 | 08:31 AM
Bullitt94's Avatar
I'd stick w/ the Dana 60's. Very strong stuff. Get your lift and put it in with the Dana 60's.
carebear3030
Nov 16, 2008 08:43 PM
heytat
Jan 18, 2006 09:49 PM
bkito
Sep 2, 2005 01:34 AM
carebear3030
Jul 21, 2005 10:11 PM
ricekiller2003
Apr 21, 2004 09:03 PM
