Bergman
Old Feb 5, 2019 | 12:23 PM
Bergman's Avatar
Default Bergman
1992 f150 pickup got fuel and spark but still want start
Old Feb 5, 2019 | 02:19 PM
Could you please tell us how you determined you have both fuel and spark? It's always very interesting how some folks arrive at their conclusions and not meaning to belittle some methods, but better to know the method than to assume everything was done correctly.
Old Feb 6, 2019 | 07:36 AM
Bergman's Avatar
Brought piston to number one made sure distributor was pointing to number one made sure fuel was to fuel rail and injectors
Old Feb 6, 2019 | 04:09 PM
OK, this is what I was concerned about..
The only way to really be sure of fuel supply is to place a gauge on the schrader valve on the fuel rail.
Different engines have different fuel pressures and guessing is out !
You can rent a fuel pressure gauge from some auto supply stores. That way you know if fuel supply is a problem or not. Volume is important, but get an idea of what pressure you are getting. What engine is in your vehicle?
Old Feb 6, 2019 | 04:16 PM
Bergman's Avatar
It's a 1992 f150 5.0 302 fuel injection I did that and it's getting fuel some one told me it's jumped time
Old Feb 7, 2019 | 10:35 AM
Did you explain that if it jumped time enough , the rotor would be pointing in the wrong place?
What fuel pressure reading did you get when you checked the fuel pressure?
Can you remove a spark plug or two and see what the plugs look like? Were they dry, wet ?
thekid_jesse
May 27, 2021 04:19 AM
old_stoney
Aug 26, 2013 11:49 AM
jodic
Feb 25, 2013 07:09 AM
Stapuph
Sep 23, 2010 09:13 AM
onem2f
Jul 13, 2010 05:25 PM
