Best battery's for cold weather in Alaska
Old Jan 26, 2024 | 03:31 PM
Take91's Avatar
Default Best battery's for cold weather in Alaska
So I have a 2012 f150 ecoboost and it seems the battery's that keep being recommended fail in cold weather-10 Fahrenheit and the truck has a hard time starting. Or not starting at all. Anyone have experience and a better recommendation?
Old Jan 26, 2024 | 04:13 PM
Some questions come to mind.
Did you have the charging system checked for proper function?
Short trips may not allow the charging system to have enough time to fully charge the battery
If there are a lot of loads like heater .defroster , headlamps and whatever loads may be demanding more power than the system can deliver.
When the engine will not fire up and start running, just what does it do?
Are you installing the correct size battery that your vehicle requires?
!0 degrees F should not be any problem for a proper functioning vehicle.
What brands of battery have let you down?
Of course what kind of maintenance does your vehicle get?
When were the spark plugs last replaced ? Worn plugs can contribute to hard starting.
dhaas
Jun 10, 2019 08:29 PM
Alberto Villacorta
Aug 11, 2017 02:57 PM
GCVB
Nov 11, 2012 09:22 PM
andy1865
Jan 4, 2008 11:22 AM
bj87f150
Nov 3, 2005 01:29 PM
