Blend door actuator location 2010
Old Nov 16, 2020 | 12:34 PM
Rj vandette's Avatar
Default Blend door actuator location 2010
I have a 2010 f150 xlt ,I have no heat only blows cold, can switch vents, no dual zone, no clicking sounds behind the dash, from what I've gotten from looking it up , seems I have a bad blend door , "controls heat/ac, I've watched videos, most says/show changing it behind the radio, some under the center console and some by the gas pedal.how do I figure out which one I should change, part number 604-252, ty
Old Nov 18, 2020 | 08:45 PM
scott.butler4's Avatar
If you do not have the dual zone AC system then the blend door actuator is behind the radio/glove box.
If memory serves you lower the glovebox, remove the radio and there are three screws that hold the actuator in place.
Don Taylor
Apr 30, 2020 12:12 PM
Austin Dennis
Jan 8, 2019 01:51 PM
zmad5306
Sep 7, 2018 05:20 PM
geraldnine
Feb 4, 2012 03:28 PM
bugman
Feb 17, 2008 09:15 AM
