Blown head gasket?
Old May 6, 2024 | 05:41 PM
Concrete's Avatar
Default Blown head gasket?
I’m getting bubbling in my reservoir tank but it’s not overheating and not smoking…also seems to be running fine. Is it a blown head gasket or something else? 2010 F-150 5.4
Old May 6, 2024 | 06:30 PM
If nobody did any work with the cooling system and it could be getting rid of trapped air, might be a good idea to have a a pressure test done.
Questionable water pump seal could be pulling in air and sending it out the recovery bottle.
How does the coolant level look ?
Old May 6, 2024 | 06:44 PM
Concrete's Avatar
We thought maybe it was the oil filter adapter because the old reservoir had been blackened on the inside top and the radiator was gunky. We replaced the adapter, flushed both the engine and radiator, replaced radiator hoses and reservoir tank. Then noticed droplets on the inside top of the new reservoir. Seems to be running fine though with no blue smoke and no overheating. May have lost a little coolant since though. No milky oil either. I’ve been quoted 6,000 to replace both gaskets and timing chain. Truck only has 140,000 on it.
Old May 6, 2024 | 07:20 PM
Concrete's Avatar
Would a coolant chemical check be my next move? Then maybe a compression check? I had a mechanic tell me if it’s running fine then it has compression. I’m confused as hell.
Billys33
Jan 3, 2022 08:23 AM
de101278
May 17, 2011 07:21 AM
farmenta
Mar 5, 2011 08:33 AM
chillywilly454@aol.com
Sep 19, 2010 11:59 AM
adk683
Oct 26, 2006 03:22 AM
