A/C Aluminum Fitting
Old Jun 28, 2020 | 05:43 PM
Benjamin0922's Avatar
Default A/C Aluminum Fitting
Hello All,
I’m trying to install my new accumulator into the port beyond the firewall (evaporator). Things of note, when me and my chums disconnected the old accumulator the aluminum fitting came off with the quick disconnect end of the accumulator so now there is a hole in the firewall where I now need a fitting to seal the ac line from the evaporator to the quick disconnect end of the accumulator. The question I have is if the part (Doorman 800-684) will work to seal my ac line in the location specified above... Or will I need a whole new Evaporator and must take apart the dash to install. Please help! Thank you.
Benjamin
Old Jul 1, 2020 | 08:44 AM
scott.butler4's Avatar
Can you post a picture of what came off and of the firewall where the line goes in.
Also what year is your F150
Old Jul 4, 2020 | 08:35 PM
Default thank you
Thanks for the reply...I ended up replacing the evaporator since it was probably bad anyway.
delgriffith
Sep 19, 2013 03:30 AM
neddley
Jul 20, 2011 01:28 AM
petec
Aug 4, 2010 08:39 AM
redmgb
Aug 10, 2007 07:42 PM
elementx440
Aug 1, 2007 07:58 PM
