Cam phasers on ford 150
Old Apr 16, 2025 | 12:04 PM
Faller14's Avatar
Default Cam phasers on ford 150
Cam phaser question
Cam phasers ford f150 2010
Hey got a ford 150 2010 xtr. I get a rattle in engine area when I go through like a drive through. It only happens from time to time. Sometimes if I coming to park but only low idle.
Replaced the cam sensors didn’t do anything. Assume it’s the phasers ? How soon should I replace ? Thanks
Have about 93000 km on it. Seams to do this clutter every so often not on a regular basis. Maybe 2 times a week
It’s never in start up either though
Old Apr 16, 2025 | 07:08 PM
Oil change schedule is very important on VVT (variable valve timing) engines.
You might consider an oil and filter change with the recommended oil and see what happens..
Old Apr 22, 2025 | 06:57 AM
amesgang's Avatar
Default vvt noise
You could try a thicker oil, 10w-40.In the long run you will need new phasers.
Old Apr 24, 2025 | 01:46 PM
avensis's Avatar
Are you using a quality 5W20 synthetic oil ?
Scott1965
Jan 26, 2023 12:39 PM
Manster377
Jul 15, 2021 04:51 AM
Fordguy2448
Aug 31, 2019 05:25 PM
302rocker
Dec 29, 2006 01:45 AM
Teunekid
Nov 23, 2005 10:00 AM
