Change headlight procedure
Old Sep 16, 2006 | 06:15 PM
92 ford blue's Avatar
Default Change headlight procedure
Does anyone have a procedure to replace the headlight assemblies in a 92 Ford f150?
My are faded real bad and I would like ot replace them.
Old Sep 16, 2006 | 06:55 PM
94 4x4 ranger's Avatar
Default RE: Change headlight procedure
[sm=welcomesign.gif]Open the hood
Push back and pull up on both headlight retaining tabs, one behind and to the outside, second a bit more forward behind the headlight on the inside. These tabs retain the headlight adjusters and the whole headlight assembly.
With tabs up, carefully pull headlight assembly forward and away from the front of the vehicle.
Rotate retaining ring on the halogen bulb and remove bulb. Do not touch bulb with fingers or moisture!
Remove headlight shell from vehicle.
1406j
Oct 8, 2008 08:54 PM
myfordvan
Dec 21, 2007 12:01 PM
vw nuts
May 30, 2007 10:57 PM
dee004
May 8, 2007 08:04 PM
colt2245p
Jan 13, 2006 08:43 PM
