clutch bleeding
Old Apr 3, 2019 | 04:13 PM
sjbknight's Avatar
Default clutch bleeding
I have a 95 Ford F150 5.0 302 with 5 speed manual transmission. The clutch slave cylinder failed so I replaced the master cylinder, slave cylinder, clutch, pressure plate, and fly wheel. The clutch master cylinder I bought was suppose to have come bench bled already. I installed everything and attempted to bleed the clutch but the petal is still soft and there is a vibration at idle as if the clutch is not fully disengaging. Any suggestions would be helpful.
Old Apr 5, 2019 | 02:55 PM
Chris Herriott's Avatar
On a clutch hydraulic system you have to back bleed the clutch cylinder.
Old Apr 5, 2019 | 08:41 PM
Mightyox's Avatar
I made this mistake on a 98 explorer. That was a nightmare.
bgrosset
Mar 7, 2013 09:02 PM
DiegoMarla
Jun 29, 2009 10:47 PM
Coloradoskier
Jan 4, 2009 03:46 AM
fordprobation1
May 12, 2008 02:09 AM
Range96
Aug 13, 2005 01:58 AM
