f250 transmission
Old May 26, 2011 | 11:38 AM
bgrosset's Avatar
Default f250 transmission
I have a 96 f250 7.3 powerstroke with a 5 speed manual transmission, and i'm kinda wondering what i should do, i've talked to some people about it because i can no longer get my truck into reverse unless i turn it off, and i can barely get it into second gear, and sometimes it will come out of gear when i take off, and it grinds a little going into 4th gear. but the people that i have talked to say that it could be my master slave cylinder?
Old May 26, 2011 | 05:07 PM
If the truck has a hydraulic clutch system, it has a clutch master and a clutch slave cylinder. Usually the first thing to check is the fluid level in the clutch master cylinder.
If full, the slave cylinder should be checked. If both appear OK then it is possible the clutch linkage may need to be adjusted. If the fluid level is low there is a leak somewhere and it could be at the slave cylinder in which case it will require replacement.
If it doesn't have a hydraulic clutch system then It sounds like the clutch only needs to be adjusted to give about 1 inch of free ply before you feel any resistance when depressing the clutch pedal.
Old May 27, 2011 | 09:12 AM
bgrosset's Avatar
okay sounds like it may just need adjusting because when i engage the clutch, and release it it only comes back half way and then i need to pull it the rest of the way with my foot after i shift. so it is most likely sounds like i will not have to replace my transmission just adjust my clutch.
Old May 28, 2011 | 01:02 PM
Gary2Wheels's Avatar
Question
hydraulics are great when they are working properly.Depending on mileage,you may find yourself 'nicke and dimed' by only focusing on the linkage though.If you do the entire clutch job top to bottom,you'll know better how things really look...yep,I know it's always $...
Old Jun 29, 2011 | 07:28 AM
pravn's Avatar
first check the fluid level in both master and slave clutch, and also its linkage.
Old Mar 7, 2013 | 02:47 PM
LJAmos's Avatar
I have a 1996 f250 with the 5.8W 5 speed manual, and know its a clutch problem.
When I push the clutch in it goes straight to the floor and I have to pull it back out with my foot. I know where the master is but where is the slave sylinder? What is my problem and how do I fix it please?
Old Mar 7, 2013 | 04:48 PM
If you are looking at the clutch master cyl follow the hose/line down to the trans and the slave cyl is inside the bell housing, (the part of the trans that bolts to the engine).
Is the clutch master cyl full?
Old Mar 7, 2013 | 08:59 PM
LJAmos's Avatar
It was not completly full, so i topped it off and its a little better. Is there a video on how to bleed the line?
Old Mar 7, 2013 | 09:02 PM
LJAmos's Avatar
And how do I check the level in the slave cylender
Mike92
Apr 20, 2007 07:19 PM
kayak99
Mar 30, 2007 12:59 AM
jrose
Dec 3, 2006 11:12 AM
