Cylinder 7 Kees miss firing
Old Jul 30, 2019 | 08:07 PM
charlottetibbs@yahoo.com's Avatar
Default Cylinder 7 Kees miss firing
I have an 07 Ford F-150 5.4. I have replaced all plugs and coil packs, VCT sensor. Why does cylinder 7 keep miss firing
Old Jul 31, 2019 | 03:17 AM
If it was all only that easy.
You might want to start with a compression test. That should give you some idea where to continue.
If a problem with valve spring, or cam lobe , the results should help to either confirm or lead to addl tests to determine cause of misfire.
Old Jul 31, 2019 | 05:27 AM
raski's Avatar
Try swapping fuel injectors with another cylinder and see if the code follows the suspect injector.
djr32978
Mar 13, 2016 04:06 PM
Dallas.72
Feb 4, 2016 04:50 PM
deathrider2
Mar 21, 2013 07:23 PM
DoubleEE
Oct 15, 2012 09:08 AM
strandolous
Jan 5, 2010 12:59 AM
