distributor timing
Old Jul 24, 2017 | 01:02 PM
Aaron Miller's Avatar
Default distributor timing
i have a 1988 f150 4x4 with a smallblock 302 in it and im having trouble gitting the timing set we tried to set it 15426378 as listed by factory. it will crank wen set but no matter what we tried it wont run properly we ended up having to set it back to where it was before
Old Jul 24, 2017 | 02:17 PM
Can you provide the 8th digit of the vehicle ID #
OR the entire vin, nothing like starting from scratch, thanks.
Old Jul 24, 2017 | 02:23 PM
does it matter that the motor isnt the original. one of the previous owners had put this one in so its not the original
Old Jul 24, 2017 | 03:38 PM
From the info I have , a carburetor 5.0L engine used a firing order of 1-5-4-2-6-3-7-8
A EFI engine used the firing order of 1-3-7-2-6-5-4-8.
Both firing orders on the caps were counterclockwise.
I can't at this time explain why they used different firing orders except if the engine never ran right ,you could see what happens if you try the different firing order.
Old Jul 24, 2017 | 03:47 PM
the 5.0 i have is efi so it should use the 13726548 ill have to git back to you om what the firing order really is but its really far off
Old Jul 24, 2017 | 04:51 PM
also i thought to ask how to tell if you have a 351or 302 because the motor doesn't actually say otherwise all i know is the intake matches that of the 302 in the bronco i have but there are also some differences between the two
Old Jul 24, 2017 | 05:09 PM
I believe the firing order for the 305 and 351 EFI engine is the same.
Old Jul 24, 2017 | 05:13 PM
ok so ither way it dont really matter witch one is witch just as long as there is the correct timing
Old Jul 24, 2017 | 06:18 PM
Let us know how you make out.
Old Jul 24, 2017 | 06:20 PM
will do thanks hanky just gotta wait till i have some time
NickTurbo
Apr 1, 2012 09:21 AM
FIRE RANGER
Dec 6, 2009 01:17 PM
Qaiphyx
Apr 4, 2008 11:59 AM
jrocco
Jan 28, 2005 04:08 PM
jfhattsr
Oct 21, 2004 05:46 PM
