EGR check engine
Old Jun 3, 2007 | 04:17 PM
msu_fan16's Avatar
Default EGR check engine
I just bought a 97 f-150 with a 4.6 liter V8. when i bought it the check engine light was on and so i had autozone check it out, they said that it was the EGR. Does anyone know what this is and how much it will cost to fix?
Old Jun 4, 2007 | 09:35 AM
Bullitt94's Avatar
Default RE: EGR check engine
EGR is the Exhaust Gas Return. It's a valve thattakes un-burned fuel/air mixture out of your exhaust and puts it back into the engine to be used again. There is a tube that runs from your headers/exhaust manifold up to the EGR on the engine. Its should have a vacuum line on it, too. Not sure about the cost. Maybe $50-$100 for the part. If you're pressed for cash, you can run without it for a while.
Old Jan 20, 2008 | 06:22 PM
jhunt47's Avatar
u likley dont have a egr problem its the egr ports that are clogged there located in the throttle
body elbow this is a common problem on 4.6l
Old Aug 20, 2008 | 05:22 PM
ronniet41's Avatar
My neighber is having the same problem and autozone said it mitght be the egr or thermostat. The code it gave was insufficient coolant temp / closed circuit or fuel control. Lookin at all the forums on here they suggest replacing the DPFE sensor. This is my neighbers car and dont want to replace something that doesnt need to be replaced I am replacing the thermostat cause it has not been replaced in three years the car is a 2003 ford ZX2 (escort) if anyone could help it would be appriciated
Old Aug 28, 2008 | 07:04 PM
jkgray80's Avatar
DPFE is an extremely common problem. Go back to AZ & ask them to hook scan tool up ,scroll to DPFE volts, should be around 1 volt during no flow. It has probably already had a couple EGR valves thrown at it so you're OK there. Easy way to check if ports in throttle body adapter are clogged is to remove EGR valve, start engine. Engine should rev out of control so be ready to shut it off. If it doesnt rev real high, remove throttle body,then adapter & get to picking out the ports.
Old Aug 28, 2008 | 07:09 PM
jkgray80's Avatar
ORIGINAL: ronniet41
Your code normally does apply to thermostat being stuck open. The engine did not reach operating temp within the time parameter.
Old Jul 12, 2009 | 04:50 PM
DavidPS's Avatar
My 12 volt AC adapter does not work, how can I fix it?
fordwoman99
Mar 3, 2013 05:24 PM
93redxlt
Mar 18, 2010 04:44 PM
fivevs
Jan 25, 2008 05:00 PM
crimey617
Aug 15, 2007 01:46 PM
bluemq1
May 16, 2005 08:06 PM
