f 150 tranny issues
Old Nov 7, 2023 | 04:56 AM
ccazs2828's Avatar
Default f 150 tranny issues
changed filter and gasket fluid was very clean small amounts of metal in pan. it will go in reverse and thats it. we were told torque converter does that sound right. ???
Old Nov 7, 2023 | 07:49 AM
There is a first time for everything, but I do not believe the torque converter is the problem, because nothing changes with the torque converter when going forward or backward.
There is a forward clutch that has to be activated for forward and It might be a good idea to verify the MLPS (formally neutral safety sw,) is sending the signal to the trans solenoids. If it is , then we need to get into the trans a little further.
Is this why you changed the filter or did the problem surface after changing the filter?
grumpyone
Oct 21, 2019 07:44 AM
kreigschnetzer
Jul 10, 2011 11:30 AM
sweener
Jan 11, 2010 11:24 PM
fordfamily
Sep 22, 2009 08:22 AM
awolb69
Jan 21, 2008 01:33 PM
