factory unlock code
Old Feb 27, 2014 | 01:04 PM
Millbornf150's Avatar
Default factory unlock code
I have a 2013 f150 4door. the factory door unlock code has been
compromised. How do I go about changing the factory unlock code? Help!!!!!!!
Thanks for any info.
Old Feb 27, 2014 | 06:10 PM
Don't know if this will work, but you can try it.
Punch in the factory code then hold in the 1-2 buttons then enter your new 5 digit code.
Old Mar 1, 2014 | 08:08 AM
makuloco2000's Avatar
There is no way to change the factory code that is programmed into the module. If you have a problem with someone knowing it you will have to get the SJB changed not too bad around $175 as changing the code to a personal pin is possible and great the fact is the factory code still will work also.
gintoni
Mar 12, 2013 05:25 PM
monkeyd01
May 14, 2008 10:28 PM
Czecher01
Jan 18, 2006 06:05 AM
DeanoNC
Jan 6, 2006 02:03 AM
seriozha
Jul 18, 2005 09:49 AM
