Four wheel drive problem
Old May 10, 2013 | 08:45 AM
fredastro's Avatar
Default Four wheel drive problem
I have a 2003 f150 supercrew 4x4.When in four wheel drive it makes a grinding noise on driver side.Only when you turn.Maybe CV JOINT? What might be the problem?
Old May 11, 2013 | 03:31 AM
You might check the u-joint at that front wheel.
Old May 12, 2013 | 09:11 PM
greasemark's Avatar
You might also check for a possible wheel bearing problem or more likely if its a ratcheting noise, a sticking hub.
db5108
Dec 15, 2008 09:31 PM
broncky
Oct 8, 2007 07:59 PM
broncky
kicker417
Sep 1, 2006 07:36 PM
smokeater3194
Feb 20, 2006 09:04 PM
