Fuel Pump????
I'm almost finished tuning up my 2002 F-150 4x4 5.4L. The only problem is one itsy bitsy thing that's driving me nutz!! Hopefully, someone can offer me directions, or suggestions?
Symptom: While driving in the Ozarks (Steep Hills & Whindy Roads), I notice that when I keep my speed or gas peddle at 50 - 58 mph, the engine chugs a bit, almost as if it's not getting gas. If I rev up the RPM's and give it gas, it doesn't do it. Or, if I let off the gas and cost, it will not do it. And, it doesn't seem to do it at other speeds. If so, it's not noticable.
Cause: Fuel Pump? Thoughts?
I've checked the Fuel Pump fuse and Relay and they're okay. I haven't checked anything around the fuel pump or gas tank. I also have checked the Inertia Switch either. I'm thinking, since my "check engine" light hasn't come on, it has to be a fuel or air problem?
In advance, thank you for your thoughts? Also, if I have to change out the pump, about how long does that take 3 - 4 hours?
jozepy24
Jul 13, 2019 05:21 AM
fordexpedition2006
Apr 21, 2017 05:23 PM
