fuel pump
Old Oct 18, 2006 | 08:52 PM
kcahill's Avatar
Default fuel pump
I have a 1996 f150 with 268000 km, the truck will not start because the fuel pump will not pump fuel to the engine, I had it towed to the garage, where it was found to be working fine, the mechanic told me that maybe it had a bad ground,after taking the truck home and shutting it off, it would not start,when you turn the key on you do not hear any pump cut in, I have read in your forums about the fuel pump relay. where is this located on this model . Any help would be appreciated.
Kevin
Old Oct 19, 2006 | 12:22 AM
94 4x4 ranger's Avatar
Default RE: fuel pump
[sm=welcomesign.gif][hr]It does sound like the fuel pump relay.[hr]It is located on the inner fender well under the hood in a black box called the power distribution box.[hr]Try to swap it with the A/C relay it should start up.[hr]If not the pump is bad.
Old Oct 19, 2006 | 01:12 AM
Either of the tank pumps run?
The fuel pump relay is in the Power Distribution Box under the hood, on/in the left fender apron area.. Relay #2 is fuel.. Check the fuse as well, but wouldn't most likely be intermittent.. And, listen 'very close' when cycling the key to the 'ON' position, or if the starter is 'bumped' for the relay to cycle off with a click after a few seconds or more.. Might help to have someone at the Power Distribution Box to verify any cycling at the fuel relayl.. The relay 'time on' is controlled by the PCM.. You can swap it for the horn relay (#3) to test for a bad relay.. PCM relay should click ON as well with a key cycle/switch to on..
Fuel pumps will/can go intermittent for run times, and sometimes if the pump/tank is bumped moderatly hard by hand with the key ON, the pump will snap back to life, or if jarred being towed ect.. Sometimes even after a 'sit' time.. Also, but not that often, the tank selector or Inertia switch can cause a no run condition for the pump/s..
[IMG]local://upfiles/6756/FB38E3EE2D044B31AD300CA43E74BFD6.gif[/IMG]
Old Oct 19, 2006 | 09:30 AM
kcahill's Avatar
thanks for the information guys , i am going to check the relay and fuses , but where would the inerta switch be located.
kevin
Old Oct 19, 2006 | 12:50 PM
In the upper right kick panel area.. Has a button on top that 'pops up' should the switch go open from an impact.. Not usually an intermittent occurance, and low failure numbers, but go to know its local if you ever get bumped hard.. Also, an easy place to test for current to the tank switch when diagnosing for power feed to the switch/pump/s.
jozepy24
Jul 13, 2019 05:21 AM
fordexpedition2006
Apr 21, 2017 05:23 PM
Spaznaut
May 24, 2014 02:10 PM
ballaholic29414
Nov 12, 2010 06:04 PM
grumpydave
Jan 18, 2008 03:15 PM
