Grinding noise coming from the front end
Old Apr 21, 2008 | 12:03 PM
SundownSVT's Avatar
Default Grinding noise coming from the front end
I just did the front Brakes on my 2005 F150 4X4. The truck stops like new but when i get on the gas even slightly I get a sever rattling noise from the front right wheel.
I suspect this maybe an ABS issue
any thoughts or suggestions would be appreciated.[/align][/align][/align]Will[/align]
SundownSVT's Avatar
Default RE: Grinding noise coming from the front end
took the truck for a drive and put in 4H and the nsie completely went away.
Now im wondering if its the auto hub rattling????[/align]WTF[/align]No Idea!!![/align]HELP[/align]
Old Apr 22, 2008 | 12:08 AM
jr78's Avatar
I don't think your 150 has auto locking hubs, the axle is bolted to the hub. The ABS tone ring is in the hub, so you almost couldn't have damaged that. You may need to remove the wheel and double check your work, look for anything loose, or an ABS sensor wire rubbed through.
Nrod
Aug 30, 2016 02:16 PM
concrete guy
Jun 26, 2014 11:14 AM
steveandbelinda
May 9, 2006 11:29 PM
96explorerXLT
Apr 21, 2006 07:28 AM
