Harmonic Balancer
Old Aug 15, 2005 | 04:32 PM
debklotz's Avatar
Default Harmonic Balancer
1995 Ford F150. Can't find any books with pics to show how it's done. HELP!
Old Aug 15, 2005 | 05:22 PM
Ramrod48's Avatar
Default RE: Harmonic Balancer
what,ya trying to do with it , remove ? , Install ?, What size Engine ?
Old Aug 15, 2005 | 05:26 PM
debklotz's Avatar
V8, 5 liter. Replace it. I know the puller thing, just would like some pics if available somewhere, even Haynes doesn't have pics
Old Aug 15, 2005 | 06:14 PM
Ramrod48's Avatar
sorry dont have access to any pic's ,, with the timing cover in place , an the seal instaled ,you need to make sure theres no groove worn in the shaft other wise it will leak , they make a speedie sleeve kit for it if it does have a groove. Comes with instructions on how to install , polish the shaft up real good , clean with some brake kleen . put a dab of loctite over the shaft , install the ring , put a driver over it , Smack it with a hammer till seated , An then pull off the excess lil tab that sticks out . I lube up the shaft with the key way , put a board 2x4 over it , ( if I dont have a long enough bolt )wack it a couple times with a dead blow hammer , to seat it cause you can never get it started with the standard bolt , so you gotta tap it on , you dont want to hit it directly with a hammer . Put a dab of silcone around the large flat washer , an put a dab on the threads where it enters the crank , grab the ole ingersall rand 231 , an run her in,, if you gotta crank it in by hand I try to lock down the flywheel to tighten it up so it wont turn on me, wedge a big screwdriver in the fly teeth , if its in the truck , Then bolt on the pulley hub,..... The ole 460 were tricky they had that 2 piece set up to add extra balance to the crank...
Old Aug 16, 2005 | 03:16 PM
cctxfish's Avatar
Here you go:
http://www.autozone.com/servlet/UiBr...3d800a2735.jsp
Old Aug 16, 2005 | 04:54 PM
Ramrod48's Avatar
Thats a pretty picture .. I's keep a fergetten about that Auto zone site . Hey did you see that site on TSB ??
Old Aug 16, 2005 | 08:56 PM
cctxfish's Avatar
Have seen and used it, but now I can't find it. Why don't you post up the link. Thanks
goodeyman
Jan 3, 2012 07:20 PM
dosnotches
Jul 2, 2009 10:00 AM
1994 F-150 5.0 2wd
Jun 13, 2009 01:45 PM
dragbike425
Jun 5, 2009 10:47 AM
dragbike425
Jun 5, 2009 10:45 AM
