Heater core problems
Old Jan 28, 2012 | 04:38 PM
jbcbussoft's Avatar
Default Heater core problems
I have my dads '92 F-150 4.9L. The heater wasn't working so I took a look. There was sludge in the radiator so a flush was in order. Along with the flush I replaced all of the hoses (radiator and heater), and the thermostat. I still don't have a working heater. I pulled the heater hoses and flushed the core There was some color to the water but it soon ran clear, both ways. After the engine reached operating temperature I discovered that the inlet hose is too hot to hold while the outlet is just a little warm. any ideas?
Old Jan 28, 2012 | 04:54 PM
If air gets trapped in the heater core sufficient coolant cannot circulate to provide good heat output. With the engine idling if you can back off the upper heater hose from the heater core to allow any air to escape, that is one of the ways to get the air out.
If it isn't a trapped air problem the heater core itself may be so plugged that you may need to replace it.
Old Jan 28, 2012 | 05:09 PM
jbcbussoft's Avatar
The inlet and outlet are side by side. I don't have an upper and lower. Which one?
Old Jan 28, 2012 | 05:59 PM
In that case with the engine off just slightly pull back either hose and see if any air comes out.
davidp
Oct 29, 2005 11:28 PM
ericftz
Sep 3, 2005 09:02 PM
ericftz
dmanlyr
Jul 9, 2005 03:34 PM
rugrat
May 6, 2005 03:18 PM
