I need advice
Old Oct 24, 2017 | 10:18 PM
Hopsfarmer's Avatar
Default I need advice
I stopped for gas today and when I went to start my 2011 F150 XLT Super Crew 4•4 it acted like the battery was low, so I get home and park it, about an hour later I try to start it , but it just clicks, so I check the battery terminals and they are good, I go to put the key in the ignition and as soon as it’s in it starts clicking and I haven’t even turned the key? What could cause this??
Old Oct 25, 2017 | 11:52 PM
Welcome to the site..
Being a 2011, if the battery is original you'd be about due. A simple state of charge or volts/load test would prove out a battery issue, possible charging system but unless indicated on the panel, dim lights etc, probably not.
When the battery voltage drops off it will rattle the dash relays and the anti theft will cause problems from the low condition...
carebear3030
Nov 16, 2008 08:43 PM
birdeeshot
Jan 20, 2006 12:28 AM
bkito
Sep 2, 2005 01:34 AM
carebear3030
Jul 21, 2005 10:11 PM
ricekiller2003
Apr 21, 2004 09:03 PM
