I stumped 2 ford service guys...
Old May 4, 2009 | 07:35 PM
paf150driver's Avatar
Default I stumped 2 ford service guys...
Ok lucky me again...
This time we have a stater problem.
lets start with the key
the key is connected to the gear
the gear is connected to one half of the actuator
one half of the actuator is connected to the other half of the actuator
and the second actuator is connected to the pin in the starter switch which is connected to the steering column.
the actuator slides in a closed channel through the cast assembly that makes the steering column
turn the key it pushes the pin and starts my truck
unfortunately if you turn the key back one half of the pin comes back but the part connected to the switch does not move
so my actuator halves are no longer connected
I pulled the steering wheel
and got my fingers on both ends of the actuators but could not get them out
and it appears the pivot of the tilt wheel must be disassembled in order to get at the pieces
my question
has anyone ever heard of this repair
does the pivot need to be broken (two very tight torque head bolts)
can a front stoop mechanic pull it off
Old May 5, 2009 | 06:36 PM
way2old's Avatar
Yep. The tilt needs to come out. There is a tool that removes the pins that are holding the tilt column in place. There are threads inside the center of the little torx headed bolts. You might go to Autozone and they should be able to print out instructions. The little tool is not that expensive, but if you only use it once, it is a costly tool. Here is a link to a tool.
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old May 5, 2009 | 07:55 PM
JTGrant1's Avatar
I have had to replace the pivot before on a truck i used to have. its kind of a pain, but doesnt take that long. Before i replaced it i took the bottom cover off the collum, and bent the pin/shaft down. That way i could still start the truck by hand. Good luck.
Old May 6, 2009 | 04:34 PM
thank you very much for the info and the link.
I am currently driving with the switch loose so I can hand start...
Old May 28, 2009 | 09:50 PM
impreza's Avatar
Default ignition
hey i got a question...I bought my 86 150 4x4 and it had a slide installed on the under panel. and i was wondering what i might have to do to get it back to a key again??? any ideas?? thanks
d1badz
Dec 15, 2008 04:48 PM
mttduley
Aug 27, 2008 03:13 AM
gbangel420
Apr 1, 2007 08:33 PM
kellybb
Oct 13, 2006 01:22 PM
headstro
Dec 18, 2005 03:09 PM
