impossible fuel filter??
Old May 25, 2006 | 12:56 AM
mexiburger's Avatar
Default impossible fuel filter??
My question is not with the lines, i got that part figured out. should you be able to get to the filter without removeing the front fuel tank? the taink covers the filter and i cant even get it out of the clip that it's in. is this normal or do i have some sort of a extra capacity longer tank or somthing?? also the line too dosn't fit between the filter and the end of the line, so do i have the wrong tool?
thanks
mexiburger
Old May 26, 2006 | 06:53 PM
frdtek05's Avatar
Default RE: impossible fuel filter??
I've seen a few times where someone has installed the wrong filter and had a heck of a time getting it out. The old style uses plastic clips to secure the line to the filter. The necks are shorter, but they still clip into the newer style hose. Since the neck is shorter, you have no room to slide the tool in. Each time, it's been a gasoline bath while I hack-sawed slowly at the necks to make room for the release tool. That could be your trouble as far as the tool goes.
I've never seen a filter in such a location as to require removal of the fuel tank. What year and body style is it?
Old May 27, 2006 | 01:57 PM
mexiburger's Avatar
yep that sounds right so Ill be getting my hacksaw out.
now for the location problem, it's a 92' extended cab and I dont know if you have to take the tank out. maby I'm just being a baby and not trying hard enough.....
Thanks for your help
mexiburger
Old May 29, 2006 | 12:03 AM
grampztoyz351's Avatar
The old style filter uses a different style quick release tool if you don't drop the tank. check a repair manual for details
Old May 29, 2006 | 02:51 AM
frdtek05's Avatar
Yep, I've seen them. They are a pain but I have gotten them out. There's a shield thats right in the way. It's a real booger.
ORIGINAL: mexiburger
mexiburger
Old May 30, 2006 | 03:54 PM
mexiburger's Avatar
well I gess i should have tried harder, but it's nice to know it's possible.
I sure appreciate the help you all have been
Use Common Sense
Sep 12, 2008 11:20 PM
kewiegand
Oct 27, 2007 07:17 PM
gwald
Mar 26, 2006 01:09 AM
jdog
Jul 28, 2005 09:02 PM
darthracer777
Jun 6, 2005 02:06 PM
