intermitten miss
Old Jul 16, 2020 | 07:03 PM
HHHBTN's Avatar
Default intermitten miss
Ill ask this here since i didnt want to hijack the compression post.
Have a 1994 f150 with 4x4 and 5.8 automatic. I had a miss not real bad but noticeable so i changed the plugs, new ford wires and cap and rotor an the thing runs 100% better and just once in a while sitting stopped i have a tiny miss. is there some other source for a miss other than above mentioned that im not seeing?? It is not a regular or steady miss.
Thanks
Old Jul 17, 2020 | 05:27 AM
raski's Avatar
I would check fuel pressure which should be 30-45 psi. Check for vacuum leaks. Replace any faulty vacuum lines.A lean miss might be possible.
Old Jul 17, 2020 | 10:49 AM
HHHBTN's Avatar
Thanks raski: one question the fuel pumps on the 1994 f 150 has two tanks are there two pumps? have to check both? thats something i never looked at I just assume they use in tank pumps like everyone. I have checked for vac leaks til i was blue in the face and the vac gauge an all tests say not one.
Thanks for any info.
Old Jul 17, 2020 | 03:36 PM
raski's Avatar
Each tank has a low pressure pump in them and there is a high pressure pump common to both tanks along the left side frame rail, about under where the door is.
Hopefully your vacuum gauge is steady between 18-22 inches.
Old Jul 18, 2020 | 11:35 AM
HHHBTN's Avatar
if i remember correctly the vac gauge is steady at 15 we are at about 4700 ft elevation i understand that is good???
Thanks
Old Jul 21, 2020 | 12:14 PM
Do you have a timing light to use ?
We are not looking to use to check timing .
Old Jul 21, 2020 | 01:09 PM
HHHBTN's Avatar
I dont think i do hanky, I think my kid took off with that years ago. Do i need to find one?
Old Jul 21, 2020 | 02:06 PM
No, not really. I was going to suggest you check each individual plug wire with the light and if it was something aside from the plug, you would be able to see it.
Old Jul 23, 2020 | 05:56 AM
raski's Avatar
Did you check fuel pressure as suggested in # 2?Low pressure can cause a lean miss.If you have a tach. a miss will cause a fluctuating engine idle. I even seen a few engine mounts which were not in very good condition caused the engine to move excessively making it look like an engine idle issue. If everything checks, a compression test of all cylinders may be needed. If the highest and lowest cylinders are more than 20% apart, you will never get an engine to run perfectly smooth.
Old Jul 23, 2020 | 10:25 AM
HHHBTN's Avatar
yes raski i did comp test ran 136 to 131 over 8 cyl i was quite happy. Did however eliminate the miss. Seems changing everything and running it down the road a few miles it has disappeared an i dont miss it a bit. pun intended. Thanks everyone for the help evidently it was a flakey wire on a plug.
Phantom_Ford
Apr 27, 2018 06:58 AM
ac917x
Jan 15, 2012 06:12 PM
chuloboy
Jul 25, 2011 02:20 PM
whippet2@verizon.net
Mar 16, 2008 02:03 PM
JoeFed
May 17, 2007 07:20 PM
