Kick down cable issues
Old Jun 8, 2017 | 05:27 PM
Jeremy Marr's Avatar
Default Kick down cable issues
I have a 68 F100. Has a rebuilt 87 302, Holly carb, and a c6 transmission. When I got the truck, there was no down-shift (detent) cable. Original motor was a 6cyl. Would a universal cable work in my application? Or do I need to try and find the old style shift rod and modify it? I would really like to try this ride down the road with the cable working.
Old Jun 9, 2017 | 02:00 PM
I would need to do some more thinking/research as to whether the detent is moved forward or rearward. If you have it attached to the throttle arm on the carb, pulling against spring tension a cable could work if you could anchor it properly.
It gets a little difficult to set up a cable to push something although it is not impossible.
You might wind up looking for or fabricating a rod set up.
jmo1112
Dec 10, 2010 02:27 PM
stclist111
Feb 19, 2010 08:38 AM
arch3angel
Jan 4, 2008 03:27 PM
bardo
Apr 17, 2007 09:57 AM
harleybadboy2
May 1, 2005 11:22 AM
