Need Help
Old Mar 6, 2016 | 10:51 AM
cire_g's Avatar
Post Need Help
I have a 1999 ford f150 4.2l truck and I am going to replace the spark plugs, spark plug wires and ignition coil, what else should I replace one I'm in there replacing these parts? my truck is 248k strong, its running rough so I thought id replace those stated parts and I also hear a loud pop under my driver side when I accelerate. I am also going to eventually have to replace my catalytic converters direct fit bolt on eventually but for the time being I am replacing those state parts but I need to know what else I can replace while I am replacing those other parts.
Old Mar 6, 2016 | 11:13 AM
Suggest you make sure to check the spark plug gaps before installing and use dielectric grease on both ends of the wires when installing.
Old Mar 6, 2016 | 12:33 PM
cire_g's Avatar
so they do not come gapped already?
Old Mar 6, 2016 | 12:39 PM
cire_g's Avatar
so if I am replacing the spark plugs, wires and ignition coil what else should I replace in that area?
Old Mar 6, 2016 | 02:54 PM
Different engines may use the same plugs with a different gap, best to check them. Don't forget the PCV valve!
Old Mar 7, 2016 | 10:02 AM
Shay_Fox's Avatar
Agreed hanky !!
Old Mar 7, 2016 | 10:05 PM
cire_g's Avatar
Any recommendations on direct bolt on catalytic converter for my 1999 ford f150 4.2l truck?
Old Mar 10, 2016 | 03:50 PM
LakelandFordParts's Avatar
Former Sponsor
I did a quick search on this converter and it doesn't look like Ford makes it anymore. I would suggest trying Summit on this one.
Old Mar 10, 2016 | 06:34 PM
cire_g's Avatar
So what would I look up
Old Mar 11, 2016 | 10:38 AM
Former Sponsor
You would go to Free Shipping on Orders Over $99 at Summit Racing and then enter your make/model information. There are other aftermarket companies as well but I have bought from Summit before and I know they are good.
